Not trying to go OT, but have you noticed good results after going with a turbo blanket? under-bay temps lower? Do you notice any coking or do you let your car idle for a bit before turning it off (or turbo-timer?)KUILLIN_DRIFTER wrote:honestly man ebay's your friend here. Not bad prices. I bought my blanket from a shop on ebay.
i can get you the same black or silver turbo blanket for $100 shipped. probably $5 cheaper if i can get a group buy going, maybe for 20 people?. the turbo blanket definitely lowers the under hood temperature dramatically. especially if your turbine is near the brake reservoir.ANVIL wrote:where is the best place to get a turbo blanket and some manifold black heat wrap? i want to wrap my dump pipe with the manifold wrap and also wrap my steering rack with that silver heat shield. is 120 a good price for a turbo blanket? what do u guys suggest?
they hold up just fine; i had the flat-silver one on my car for 2 years on a 60-1 before i sold the car.they went to shiny silver now.Darius wrote:That seems like a fairly reasonable price. How does each color hold up? Do they fade or become chalky etc.?
What sizes can you get ahold of BoostFab?
I have mine ceramic coated inside and out, but it is still a little warmer than I'd like it to be under the hood. Then again, I'm anal.
please email me.krayton wrote:20 people sounds like it could take to long. ill just take one for 100 shipped
was gonna order from phase2 for a lil more
So you do not recommend wrapping the stock cast exhaust header? Just a blanket and DP wrap? Is this better than the stock heat-shield for the elbow?BoostFab wrote:what manifold are you using ? typically i don't recommend wrapping manifolds, especially if it's stainless and cast.
you don't need to worry about the heat of the lower section of the downpipe, but wrapping the upper section also help lower heats in the engine bay.
as for wrappers, these are pretty standard; look on summit racing, i think you can get best deals on there. i don't deal with heat wrap, only the turbo blanket.
