turbo bearings: types and info?
overboostn07
Car: 1993 nissan 240sx se 1987 chrysler conquest tsi
what is the difference between these 3 types.
1- wet floating bearings2- ball bearings3- ceramic bearings
also i own a turbo also known as a triple k made in china, cheap turbo but had it rebuilt by a professional because i was told the lifetime was very short because of the bearing type, "wet floating" now are they really a cheap turbo and bad bearings causing the short life or is it because they are only oil cooled?
when purchased it was called a super t70 but the pro. told me he doesnt understand why its called a t70 because there is nothing on the turbo associated with the number 70.
brings me to my main question, is it really called a triple k turbo and what are the specs and or short learning lesson about the turbo anyone could give?
shaft and wheel trim 64.5mmcompressor wheel 60.5mmturbine housing a/r .84compressor housing a/r ".70" supposidly?exhaust housing is a 3" v-band flange
thanks ka-t guys!!!
WDRacing
Journel Bearing/Bushing
Ball Bearing
Turbo Breakdown
The Ceramic Ball-Bearing concept that has essentially eliminated any concern of turbocharger durability in high performance applications. The heart of this concept is a NASA inspired angular ball-bearing fitted with almost indestructible ceramic balls. The thrust capacity of this design is rated at over 50 times greater than conventional turbocharger thrust bearings!
pr240sx
Now...will be nice to upgrade a "normal" turbo CHRA into a ball bearing one..
WDRacing
WHy not go ceramic, they last forever and spool quicker. Just aquire a Skyline T3 and use the center cartidge. I could get whole RB20's in Japan for $250, so a turbo should elcheapo.
WD
pr240sx
But it can be retrofitted?
Maybe a bearing insert of some sort.
WDRacing
I have a spare T3 here from one of my Skyline projects, I'll tare it down and post what I find.
WD
NateDogg
I believe Turbonetics is the only company that uses ceramic ball bearings as it is patented.
WDRacing is referring to ceramic turbine wheels not ceramic ball bearings on the RB turbos.
