Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Dec 09, 2008 8:01 am
The journal bearings in a turbo are a floating bearing design, unlike the bearings you find in your motor. This means it will spin independently of the races holding it in place.
The major pro of using a journal bearing turbo is maintenance. Rebuilding a bushed (ie journal bearing) turbo is easy and cheap, where as with a ball bearing turbo, you have to usually replace the center cartridge, as the ball bearing is pressed into the center housing. I can buy a rebuild kit for a bushed turbo for around $100. The cost of a new CHRA for a T28 style turbo ranges from $600-$900.
I've seen turbo volvos clear 200,000 miles without requiring a turbo rebuild, and they're bushed turbos. Turbo life expectancy is much more dependent on use and power output. The formulaic lifespan of a turbo will never be actualized as you will kill a turbo due to abuse long before old age will take it.
