Edub1 »
https://forums.nicoclub.com/edub1-u34344.html
Fri May 18, 2007 3:57 am
Ok, here is the deal. You are only looking for a bit over 200HP correct? The stock MAF is good for around 270HP and is far easier to tune, so keep your stock MAF. Yo have 370cc injectors - you will need an SAFC to tune for these or you can't use them, got it? Plus, you do not need or want a big turbo. A T3 super 60 will be more than enough to deliver what you need and it will spool faster. So, here is the bottom line and you don't have to ask the same questio again.
Get a T3 60 trim or super 60 trim - T25 will also work.Use 370 injectors and your stock MAF - tune with an SAFCTiming should be fine for 5-7 lbs - to be safe run at least 1 step colder plug, use high octane fuel and maybe turn your dist back 2*.
Don't forget, you will also need a blow off valve and exhaust work.
If you don't have money for an SAFC, sell the 370s and buy a 8:1 FMU to use with the stock injectors and MAF.
Got it?
