480sx »
https://forums.nicoclub.com/480sx-u50548.html
Mon Feb 11, 2008 3:37 pm
Why would you post a picture of a longblock with manifolds, out of the engine bay, with a huge topmount on it lol. That doesnt help this guy at all.
You need to rent a timing light from a parts store. Hook the battery leads up, then the clip on number one wire.
Then, aim the light at the crank pulley on the right side as looking down from the front. The light will blink on and off, and aim up at 6 marks on your pulley. Sometimes it helps to mark the ..marks on the pulley with like orange/green paint.
Your trying to see if your engine is 'timed', or lined up with the first mark that passes the rod(coming out of your lower timing chain cover next to your crank pulley on the right) that you use as a reference when looking at the crank pulley.
