Nissanclubman »
https://forums.nicoclub.com/nissanclubman-u79352.html
Fri Apr 17, 2009 3:23 am
Hi Dave, Great to see another (LOCOST) Clubman builder venturing in with the plans to use Nissan harware. I'm a fellow builder and put mine on the road in 1999 and have been upping the performace limites ever since. I decided on the CA18DET for a number of reasons and looking at your shopping list you have similar intensions of developing some serious hoursepower for such a lightweight car. Great to see you also used teh Nissan R200 diff and asumed you also have gone with a wider chassic to cater for the wider track. Beautiful job and being a fellow builder know exactly what your going through. Anyway my thoughts:
If you haven't committed to a DE (appears you have however) and you can get your hands on a DET then I support that for sure, particularly if you end up like me, want more grunt and start cranking up the boost.... In the early days however tuning the DE won't be much of a problem and lots of suggestions already on offer on this thread. Stay with the standard JDM ECU. These can be tuned to do anything you want and are dirt cheep. The T25 or T25G would be my suggestion if using a DE, with some minor mods to the oil delivery these will live a long life pushing up to 15psi. They spool up nice and quick and will bring you buttom end torque on line nice and early. Mind you being a DE you will have quite a bit already. Once you start tuning beyond 10-12 PSI then you will need to replace the 50mm AFM, the Std unit run out of range at 12 PSI, after that then your ECU struggle to fuel the car correctly.I wouldn't worry about a wide band O2 other that what has been suggested for initial tuning. The motor only uses it during closed loop running in any case. Under any level of boost your ECU runs pretty much off the AFM, VQ profile, Injector opeing duty scale, latency setting then adds to that what it reads from the fuel map. The O2 sensor isn't involved at the business end of things.
From an exhaust point of view the standard DET header/dump pipe is more that enough for up to 230 HP (flywheel) before any detectable restrictions come into play and by then you will be needing to make some other changes in any case.
Your standard 370cc injectors like wise are pleanty good enough for early days tuning and if married with the Std AFM, T25(G) turbo, STD exhaust, you can certaily get to around 210-220 (Flywheel) HP.
Afer market fuel regulator..... can't see the point. All your tuning is based around an injector size which is asumed to being fed fuel at a standard pressure (range because it tracks with boost). If you go for biggish HP and upgrade to larger injectors (Skyline RB26... for eg) 440cc then they will operate very nicely on the std fuel rail preasure. If you up your rail pressure then you will need to retune for that and in the end if you select injectors wisely you will only be delivering fuel as per what the ECU decides it needs from what the AFM tells it. All of this asumes the fuel rail pressure to be standard, albeit tracks up and down with boost. A pretty simple job really and the Std regulator does just fine.
This would make it pretty cheep to build, give you losts of scope to tune up your HP and if you go beond that you will have to change a number of things. AFM, Intercooler, Injectors, Turbo, Exhaust so start saving your $.
Having said that you will already have a 0-100 kph in mid 4 sec car on standard hardware and that may very well suit you fine for a while.
Good luck with your project and will watch your progress. Keep your WEB site current because it is pretty exciting stuff you are doing.
These are just my thoughts and hope no one takes it too seriously. There are alway may ways to skin your question. Cheers for now Richard
