Dustin240 wrote: How about total energy put down to the road threw the entire rpm range?A smaller turbo will start making power sooner. And a big turbo will have a little more power up top but not enought to overcome the wider power band of the smaller turbo.
less energy required to drive the larger turbine, better aerodynamics >that energy is almost free so how cares.
And chezadik, A small turbo can make 100cfm to 8psi, or a larger turbo can pressurize 200cfm to 8psi. Thats what makes a large turbo better on larger engines but engine can only hold so much air. So if a turbo can make 8 psi in the cfm range of the engine your good.
I wasn't talking about bigger or smaller. I said more efficient at a given pressure ratio and flow rate. I made no reference to size at all...quite deliberately. The tendency is a larger turbo's peak efficiency island occurs at higher flow rates and pressure ratios and smaller turbos tend towards the opposite. But this is not always the case.
And if you want to argue top end vs having a broad power band, take not the RPM at which each shift at redline lands you in each gear. The only time you'll see less than about 4000-4500 RPM is in 1st gear. You'll spend about 2 seconds in 1st gear in a 1/4 mile while the rest of the time is spent in all other gears at higher RPM's.
No energy is ever free. While turbos use a lot of the excess energy being expelled out of the exhaust, turbos still create backpressure on the motor. Smaller turbines are generally more restrictive and require higher backpressure. Especially when the compressor is in an inefficient range. Larger turbines are less restrictive and even less so when it's in the compressors higher efficiency ranges. It's not uncommon to see small turbos run more backpressure than boost. It's not uncommon to see large turbos have less backpressure than boost.
I'll try to restate the point chezedik was trying to make a different way. You can fill a 0.6L cylinder with 8 psi of air at 100 degrees farenheit or fill it with 8 psi of air at 200 degrees(don't use the numbers as realistic, just making a point here). The cylinder filled at 100 degrees will have much more air than at 200 degrees. 8 psi of 100 degree air and 8 psi of 200 degree air is not the same.
