Biggamehit »
https://forums.nicoclub.com/biggamehit-u25242.html
Thu Mar 15, 2007 11:38 am
Last week i found a H1C on eBay that i was looking for when i built my turbo kit last year. To my luck not only did i find it, but the shop was located in Rockville MD. I talked with the owner of the company and he allowed me to come check it out before buying. The turbo was as described, " zero shaft play no leaks etc". He also allowed me to browse through his shop freely and was very excited to show me his latest turbos that had Zero miles on them etc.
This shop houses EVERY holset ever made (H1C,H1E,H2C,H2D,H2E,HX30,HX35,HX40,HX50,HX55,HX60,WHX80,HX82........... SOURCE) and many OEM Garrett chargers. some are rebuilds/parts only. some are in fair to new shape. many of the BIG ones power Detroit trucks, Earth Movers, Marine equipment etc.
they are great project turbos for DIY guys/gals and cost way less then the leading brands and are the same quality and better in some aspects. many of them that you see in the pictures that can actually fit in our cars without major modification are mainly T2,T3 and T4 flanged with either 4/5 bolt and v-band turbine outlets. for the most part you can use standard feed and return oil flanges. some are threaded for use with banjo bolts. It takes minor modification ( drilling, tapping, converters etc) to make them work
below are pictures of the shop and my turbo
all being shipped todaycould place 1 1/2 Razors inside of it
T2 flanged ( bigger then z31 T3)
superchargers
MY turbo
TURBOCHARGER MANUFACTURER: HOLSET #765TURBOCHARGER PART # 3522900TURBOCHARGER MODEL # H1COIL COOLEDWEIGHT: 19EXHAUST WHEEL DIAMETER - 60mm.COMPRESSOR WHEEL DIAMETER - 45mm.
I did the math for the trim and came up with 56 but that was just with the numbers given, i really want to measure the size of the inducer and exducer and get the proper number for both sides.
spotless, had you basic sludge from use, but no broken parts or blown seals ( most of the oil spots came from my fingers)
