Perrenial Badass wrote:Yea, but a factory turbo has 180whp and the NA2T is around 210. Of course, always easier to buy something you don't have to work on. But as soon as you get the turbo car, you would be wise to rip a bunch of s*** out of the engine bay to do the timing belt anyway. Might as well do the NA2T at the same time.
sorry but the n/at at the same boost levels as the Turbo would be only about 5hp more, you can only extract x amount of power form x amount of air, and when you are runnign the same turbo at the same level on both cars you have the same amount of air coing in, the higher compression ratioo will help move the air in and ot a bit mroe efficiently yielding a higher VE and a few more hp, but not 30, it's called thermodynamic's
