C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Oct 25, 2005 5:51 pm
It looks like the 0.82 A/R housing you have was designed to work woth a larger trim turbine wheel. Having a larger A/R coupled with such an oversized housing will present more inefficiencies as a lot of air will blow right past the turbine wheel. The turbine housing should just clear teh turbine wheel blades ideally.
As far as the compressor being a bottleneck...not true. Compressor A/R's have very little effect on overall turbo performance. Compressor trim is going to be vastly more important than A/R. Actually efficiency of the compressor is purely a function of boost vs flow and how it relates to the compressor map. Turbines also have an efficiency curve, but I have yet to really understand this myself as there is very little info out there about this. But in the big picture, the ideal set-up is to match the turbine and compressor efficiencies up relative to where you want the most efficiency to land during driving.
