Turbine Revolution Sensor on 90 Q45
aliciaford
Car: 1994 Infiniti Q45
I posted here a few months ago regarding the jerking/hestitation problems that I was having. I replaced the MAF after cleaning did not help, and she has run excellent until this am. Every time I turn it off I get a Transmission Malfunction indication. Through the self diagnosis, it indicated the Turbine Revolution Sensor. Has anyone had experience with this? Just when I thought my Q troubles were over.....
THanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Get the part form IoS and also the rear main engine bearing seal.
You have to drop the transmission to replace. Not in expensive nor easy.
Consider replacing rear transmission mount (3rd motor mount) and exahaust hangers also as additional labor is nil.
