Darius »
https://forums.nicoclub.com/darius-u5470.html
Thu Aug 23, 2007 4:53 pm
If you go into "Settings" from the hand controller (assuming you have one), you can change the injector correction based on your new injectors vs. your old ones. All it does it reduce the amount of time the larger injector is open by the direct proportion between the size of your old injectors divided by the size of your new injectors.
i.e. 370cc/660cc = 0.56
Your original setting should be 1.0 (370cc/370cc).
Even if you can do that, I would drive it directly to the tuner.
