Post by nismo1003 » https://forums.nicoclub.com/nismo1003-u8632.html Wed Feb 02, 2005 10:30 pm
Post by Nismo_Freak » https://forums.nicoclub.com/nismo-freak-u248.html Wed Feb 02, 2005 10:34 pm
1. You run the same A/F with and without WI.nismo1003 wrote:Without the WI activate you wanted to tune your car at 11.7(richer side to be safe)when hit full boost. But when you tune it with WI ,the A/F would be different because the cooling effect, but what kind of A/F you want to expect? I do understand that the EGT and A/F will be off once the water worked as a cooling effect, so what can I base on to calibrated this A/F reading? what I'm asking is that what kind of A/F I should looking for while the water is spraying? I did a little homework, http://techedge.com.au/vehicle/wbo2/wblambda.htm but it dones't really mention about WI ! . please share what you know ? THANX
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
