nismo_power wrote:yeah im going to let the dyno do it...so your saying that if i fine tune my car with the afc then the chances of blowing my motor will be higher???
so will i need the wide band with the controller or just an air fuel ratio gauge???i just want to make sure so that i dont spend money on things i dont need...
Wideband sensor works w/ a airfuel ratio gauge, they come together when you buy them for example AEM UEGO wideband kit which comes w/ gauge and wideband sensor. the sensor is connected to your exahust pipe, should be before the cat @ 9-3 o clock. the sensor gives you the afr reading from the exhaust gas that is exitin from the engine and sends it to the gauge so that you can tell what your afr's are. you cant use only the wideband w/out the gauge. you get?
It is better to own a wideband so that if one day something goes crazy you can tell whats going on w/ your air/fuel ratio. also if you have mail order ecu tune(enthalpy, JWT) then afcneo is one of the best way to fine tune.
or, if you're low on cash then dont get wideband and take it to the dyno shop, so that they can tune your afcneo for you. since all dyno shops have wideband, usually they get readings off your tailpipe which is good if you dont have a cat. but do-able if you're running a cat, its just that free air can mix w/ your exhaust gas giving inaccurate afr readings.
So to make it short get a wideband and know that you're running a safe afr and fine tune w/ afc. if you want you can try to learn how to do it, but this is only if you have a wideband. afc are good for fine tune, dont recommend them for people who going ka-t and only using afc(piggyback), But do-able.
If you plann on having a super reliable car then you have to invest in enthalpy, JWT, or best is standalone(thats if you have the money).
usually people blow their motor because they are stupid kids who are too anxious to play w/ their afc and are guessin their afr. thats why we have sooo many blown ka-t's out there. also bad tuners (emance)
