Tuning w/ turbo
ILikeMy240sx
Car: SR Power
I hear the term "tuning" alot with turboed engines...
What exactly do you do to tune your car with a new turbo/injectors etc etc. Do you actually have to be on a dyno to tune your car or can you just do it with SAFC or any fuel management system?
ILikeMy240sx
Car: SR Power
bump... anyone?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Well typically you use a wideband O2 sensor in conjunction with a dyno so you can see what your air/fuel ratios are at certain RPMS. Then you used a fuel controler to optimize the fuel curve. Too rich you loose power, to lean you blow up the motor.
ILikeMy240sx
Car: SR Power
Hmm i see so basically when they say Tuning they mean tuning your a/f ratio with a fuel controller...
Is is absolutely necessary to use a wideband o2 sensor and a dyno or can you just use a fuel controller to tune your motor to say 11~12:1 ratio?
Ninetyfive240sxSE
Car: learning to drive stick =p
you really need a wideband 02 sensor to tune it properly. an AFC would be a good starting point if your on a budget, but better if you have a stand alone. you can get away with a dyno, if you can drive your car in an empty long road and tune it a/f from there.
