jeff120 »
https://forums.nicoclub.com/jeff120-u26565.html
Tue Jun 13, 2006 4:38 am
Aright, to begin with my problem is this: i've been getting white smoke from my exhaust on my 91 KA24DE (fuel, not oil i think) only when i hit the gas from an idle, and only when i've been idling for a little while (like after a long traffic light). So my first guess is that i'm running rich; I'm running new ngk plugs, newish bosch wires, new O2 sensor so no troubles there. I know the wrong voltage drop from the maf ground can make KA's run rich, but when I checked my maf my multimeter read no continuity over any of the three wires coming out of it...so it thinks i don't have a ground at all. (also, i'm running a ghetto ebay cold air which may well be the root of my problem..and i think my cat. converter's on its last leg). Any suggestions as to how to check the maf voltage drop without continuity, or if not what else it may be?
