chad b. wrote:
No, that's not exactly what he's saying. I guess this is something that is only used on DSM's. You can use the stock O2 sensor voltage output on a 1G DSM to "ballpark" determine your AFR's. There is a box called a jumptronix that you can buy and wire in that tells you stock O2 sensor voltage output. With it, there is a chart that gives you a round-a-bout- idea of what your afr's are a certain voltages. It's not a wideband, and it isn't perfect. It's an old school DSM trick, not suggested for other cars. By going off of that , and also monitoring knock, you really can decently tune a 1G DSM. I tuned my old 1G AWD and went 7.7@85mph in the 1/8 on a 16g and pump gas. I beat on that car for almost 3 years tuning like that and so have 1000's of other DSM owners.
It was just a write-up that I thought would help. I never said to take it literally and do it to your KA-T. We're all here to learn guys.
BTW some of the cars that have rolled out of his shop:9 sec crx9 sec ethanol 1G9 sec EVOseveral 10 sec DSM'sseveral 11 sec DSM'stwin 42R big block Chevy sand truckturbo 700R Raptorturbo Toyota trucksetc.
I don't think you're in any position to challenge this guys expertise. How many 9sec cars do you have under your belt? I'm not saying he's perfect, but he sure as hell isn't retaded.
I appreciate you posting the information. I do agree with everything he's said (except for the o2 sensor part). And he has to be doing something right if he makes fast cars and has such a strong following. It's just disappointing to see solid advice get tarnished by one really bad advice.
I'm always leery when I hear "old DSM trick" because we don't live in 1990 anymore. We have affordable wideband sensors. I looked up that jumptronix gizmo (and yes, it will work on any narrowband sensor - not just dsm's). Guess what? It doesn't offer any advantage over any hand-held voltmeter. (Any voltmeter will read with .01 V resolution) It still uses .1 V to cover between 11 and 14.7 afr.
The jumptronix doesn't even show AFR - you have to look at the voltage and match its afr based on a little chart, which leads to another problem - the output of the stock o2 sensor is also depends on temperature:
so lets say your voltage shows .85 V.
if your exhaust temps are 400*C, your AFR's would be 14.7if your exhaust temps are 800*C, your AFR's would be about 12.
See how that can be a problem?
