:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Jul 23, 2003 10:46 pm
KA24DE, DOHC - Without boost:
Custom 3" intake, HS header, 2.5" mandrel exhaust, pulley (or set), cams (Nissan Motorsport or JWT), JWT ECU upgrade, flywheel, e-fan, and high compression will get you in the 170-180rwhp ballpark...probably no higher.
Big port-n-polish isn't that good, b/c to take advantage, you need high revs...and with the KA you're limited to 7000 or less basically...spending a lot of time above 7000 with a KA will rip it apart at some point.
Highest I've seen is 171 from 'Rownan', with all that listed above (or some variation of it).
Most bolt-on KAs have some mix of the mods listed above (ni high compression), and reside in the 145-155rwhp range...
Boost:
Expect anywhere from 10-13rwhp per PSI, depending on turbo size. My T3/T04E gives about12.5rwhp per PSI...straight T3s will give less, etc...
Stock internals = 320rwhp daily (12psi or so), but one guy put down 357rwhp on the dyno (15psi), stock block DOHC.
So there's some #s for you...
Later - Brian
