Tyler »
https://forums.nicoclub.com/tyler-u52646.html
Mon Nov 01, 2010 12:44 pm
you cant really "tune" via obd2. your consult cable is used more for feedback on what your motor is doing.
i think your thinking of a socketed ecu, which is simply tuning the stock ecu after you have modified it to accept different eproms that have your tune built into them. there are a few ways to do this, and i by no means know everything but i know a little. Before you do anything you need a socketed ecu, you can buy daughterboards online for your dual cam ecu that make it able to accept new eproms. then you have a few options, one is like guess and check where you get a chip burner and write new tunes, burn chips with your tune on them, and plug them into your newly socketed ecu and see how your car preforms using your consult port. as you probably can see, this isnt the best way because there is lots of room for error without realtime data. Your other option is to get whats called an emulator, which is pretty much plugs into your ecu and gives you realtime data and most importantly allows you to tune in real time. in all honestly, the most straightforward option would be to use Nistune as it will do what you want and eliminate lots of confusion. hopefully that all makes sense, tuning can be very confusing.
as far as programs i use tunerpro for the actual rom editing and ECU talk for communicating via consult, both of those are freeware.
check out hybridka.com tons of good info there
