http://www.e-mance.com/
go there and use one of his ecu's tell him (Jason) I sent you (Justin)
I have used his tune for over a year! he set me up with a tune that is slightly rich and slightly retarded ignition timing so i would be safe. i had no problems with his setup, its plug and play, and its cheap! very easy for someone new to turbos. all you have to do is get a set of injectors (like sr injectors) and a turbo manifold and turbo of your choice (like a jgs manifold and a t3 turbo). you tell him what you want, and what your setup is, then he will send you a new ecu with the special tune. then unplug your stock ecu and plug in his ecu, done.... if you have problems, he is very knowagable and will help you out too! there are alot of options, just send him an email or whatever...
remeber to say i sent you. lol! later...
