Make sure you do spark plugs, VQ's like to eat them upcruzad3r wrote:subcribed! - seymore4, i will contact you as soon as i'm done with my maintenance chores on the car
Your car would simply bog down and coast/ engine brake till you reached 30mph... at which point it would come back to life. Won't blow up your engine or anything, but you may need to change your underwear afterwardsbejjutsu wrote: What if you switch the map to "under 30MPH" while on the highway? I assume there are protections for that?
Its actually quite easy to do if you're not paying attention. Considering most people don't switch maps daily and the sequence you have to press with the cruise control buttons is kind of awkward at first. I could see someone attempting to switch into an economy map on the freeway and mistaking the order of their maps quite easily. Not to mention the fact that Uprev has had some trouble getting the cruise control light on the dash to blink and confirm which map you're on with some of the M romsRED_DET wrote:You would have to go through a sequence in order to switch the maps. If that happened, it would be no accident.
RED_DET wrote:These guys are dead on with the UpRev. If you have any modifications what so ever to your car, you need to look at getting a tune, period. We dyno tuned our G35 with very minor bolt-ons and the difference was night and day. You can see for yourself here:Reality of A Dyno Tune. We are also a UpRev Dealer, so if you have any more questions ask away.
Are you thinking about a plenum spacer? Several companies make them, and yes its pretty much the best mod for a VQ35DE.Twizz wrote: I have an 07 M35X. I know there is a harder time finding dynos that are for all wheel drive. I am curious though, What do you charge for a Dyno and UpRev ? Also, what do you think about the motordyne thing (I cant remember the name of it. It is said to increase power throughout the power band)
The motordyne product you speak of is probably the plenum spacer. The 5/16" basic plenum spacer is used on our G35 and it will add 10hp over stock. There are multiple dyno's out there that show those increases. Probably the best bang for your buck at this point.Twizz wrote:RED_DET wrote:These guys are dead on with the UpRev. If you have any modifications what so ever to your car, you need to look at getting a tune, period. We dyno tuned our G35 with very minor bolt-ons and the difference was night and day. You can see for yourself here:Reality of A Dyno Tune. We are also a UpRev Dealer, so if you have any more questions ask away.
This isn't exactly an M specific topic..IlyaKol wrote:Also, you're posting in the wrong section. This is the Infiniti M section, not the Infiniti G section.
