neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Thu Mar 29, 2007 7:33 am
were you the guy on normandy 2 weeks ago on lenox
anyways, your probably running a tad rich in the wot areas, and maybe a bit lean in the low boost cruise areas.
here is what happens when you put a bigger injector in without an ecu tune or eprom/emulator, the stock ecu can manage the new injectors in the low throttle/cruise(closed loop) portion of the map,then in the wot(open loop) portion its just dumping fuel like you still have stock 270cc injectors,but infact its spewing even more cause you have 30cc injectors now. ka's run a bit rich to begin with, you added to that,its safe tho in the wot areas. You may want to look at getting an afc or romtune done, I have concern about your cruise (boost/afr),plus you'll have dyno proof and a better(safer) running engine.
Dont start being cheap now, you could always get a wideband and check it out for your self.
