KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sun Dec 31, 2006 10:07 am
These are some very valid questions, and please, don't apologize for them. At least you came out and asked openly, rather than kinda floating in and out of discussions like you know what you're talking about, only to prove that you don't.
I think I can help clarify a few things for you.
A JWT tuned ECU is exactly that...an ECU that has been recalibrated for your particular setup and cannot be changed by anyone but them (because they use encryption to make the ROM information unreadable). Once you receive this ECU, you simply plug it in and go. You don't get it dyno tuned at the local shop because of the aforementioned encrypting.
JWT is notorious for having pretty slack timing (retarded too much) and silly rich fuel mixtures. The reason for this is to cover their butts. All engines are not the same, even if they're built the same and have the same exact parts. So, to cover all the bases, they just make it a little rich and retarded.
Enthalpy tunes are proven to be better than JWT tunes. RS Enthalpy does the same thing -you send them your ECU and setup specs and they return it, ready to plug in and use. These are also encrypted, so you can't retune them (or even examine the information for yourself). However, the Enthalpy tunes seem to be more appropriately calibrated.
The SAFC2 + BTM setup works well for many. Several people have cleared 300whp with that setup. While it is the same cost of a tuned ECU, at least you can have it fine tuned to optimum performance for your specific car.
The MegaSquirt is NOT for novice tuners. It requires quite a bit of wiring knowledge/ability and an advanced tuning knowledge. You'll need to be able to build base fuel and timing maps, then street tune it (for a good base), then hit the dyno for fine tuning. This might not be the best option for you.
You'll need to monitor AFR's via wideband O2 sensor if you tune any of these DIY setups on your own, without the use of a dyno. However, if you use a proper dyno facility, you won't need to invest in a wideband O2 sensor, as the dyno will have one onboard that goes in the tailpipe of the car. Keep in mind, if you have a catalytic converter, the reading will be a tad bit off, so you might want to still invest in a wideband, mounted upstream of the cat.
When you get your car dyno tuned (assuming you have a tuneable system), they'll go through many different steps to calibrate the fuel and/or timing maps to suit your engine's needs and obtain a proper balance of performance and reliability.
