klh6686 »
https://forums.nicoclub.com/klh6686-u16180.html
Tue Aug 15, 2006 7:02 pm
i went and played around with it and it seems the best way is kinda like how darius said it except a little simpler.
so you have your original columns and rows, ex 12 x 12 (A-L, 1-12)
now go to cell A14 and enter the formula =SUM(A1+1)So say you had 20 in A1, you now have 21 in the beginning of your new table
Now select that cell and drag the bottom right hand corner to the right until you get to L14 (the end of our table)
Then select the bottom right corner again and drag it down to L26 thus giving you a new table.
it sounds kinda complicated but once you get it, it doesn't take long to do.
EDIT: darius' way would work best if you were to make multiple changes such as +1, then maybe +2 you would change only the seperate cell and refresh the current table. mine is more of a one time deal
