Tuning JWT ECU and Knock Sensor
DammitBobby
Car: S13 91 KA24DET
LMAO, Hey I am running .48AR T3/T4 I don`t think it has much more then that in it.
WDRacing
Well, thats what you get I guess...
Edub1
Car: 89 240sx KA-T
You definitly have enough retard but 20lbs is getting into ultra high, special tuning boost. You might need richer AF ratios as retard alone might not do it at 20 lbs.
You should get a .63 AR housing and fix your tune before going into radical boost pressures. Just cranking up more and more boost is not a way to fix a problem, it's a way to create more.
You should already be at 350HP at 15lbs on a t3/t4. Fix your tune.
WDRacing
At high boost Bobby, you sould really consider getting a EGT gauge. With a wideband and EGT you'll be golden. Keep the temps the same and the AF the same...boost until you can no longer keep the AF's or Temps within a safe range.
I agree with the .63 AR hotside. At 20 psi Fiz made 420WHP...
