louiswun »
https://forums.nicoclub.com/louiswun-u87508.html
Fri Aug 16, 2013 3:04 pm
I hope you understand my english.
Make sure you don't have any hardware problem, no DTC code show up.
There are few items you need to check before tuning, when engine is idling.
Press F6 to show up "Consult Gauges"
ECU voltage must be steady and should be around 13v while idle, while A/C off and head light off.
TPS Idle indicator should be in red light on when throttle off.
TPS voltage 0.45 - 0.50 V when throttle off.
check ECU parts number showing in nistune software, same as your actual ECU.
check VQ map is same as your Air Flow Meter.
For JDM ECU (or any other ECU that have O2 sensor) , unplug your O2 sensor, you should see around 0.32 to 0.34V default voltage, if not ( I see 0v showing in some problem ECU), check wiring between 02 sensor and ECU, if still not found any problem, try to remove the O2 signal female pin on the blue ECU connector on engine harness side, if you still don't see 0.32 to 0.34V default voltage, change ECU.
CA18 with z32 maf, maf (AFM) idle voltage should not lower than 1.040V, if you see any lower voltage, change to a better condition maf or you wll have hard time on tuning.
If any item not ok, fix it before tuning.
If ok, warm up your engine until you see 80 degree water temperature, any lower water temperature will let the water temperature enrichment enriched your AFR.
( If your are using JDM engine, a 82 degree thermostat should be inside your engine, if you have removed it, you will be difficult to target the K value)
start tuning your K value at vacuum stage, ignore the idle AFR at this stage, just enter your injector latency from deatschwerks supplied, hold your throttle as staedy as you can, hold at 2,500 rpm no engine load free rev, adjust your K value until you see 14.7 AFR, let off the throttle fully fast, while engine reving down, watch your AFR gauge, if you see your AFR have a rich spike then goes to max lean and then back to idle, thats mean your latency setting is too hi. (or your BOV spring too soft, fake AFM signal created)
If you have a too low latency, you will have instant max lean, and idle on lean side)
At this stage, a correct latency + correct K value, a too hi latency + too low K value, or a too low latency + too hi K value, all cases will have same 14.7 idle AFR.
0 all TTP min and 255 all TTP max.
Set your idle TP in the lowest Fuel/Ignition load scale, mine is 11 with 550cc injectors, yours should be lower with 800cc injectors.
set your fuel map left hand side (vacuum and low load side) to all 0 (Raw value).
open "input tracer" window , it is something like runing log, it helps tuning a lot.
start crusing on long flat road, 2nd or 3rd gear both ok, try to use your throttle to hold your pressure in 0 vacuum / 0 boost ( 0 psi), watch your boost gauge with one eye, watch your road with the other eye, while engine rev up, keep it in 0 psi steady while rev climbing, 2,000rpm to 5,000 rpm is ok, AFR should be close to 14.7, if not, adjust K value and repeat until you see 14.7, also check your max TP at 4,000 rpm in input tracer, let say if max TP is 32 (550cc + Z32 MAF usually see 32, 800cc + Z32 MAF should be lower) now you can determine how many column in your fuel/ ignition maps are for vacuum, let say you only need 6 column for vacuum and 10 column for boost, input 32 into the 6th column in your load scale, then line up the 1st to 6th column in the 2D map.
Select your fuel map display in "estimated AFR", set your AFR to all 12 AFR on the right hand side of the map, set your accuator or boost controller to the lowest boost, set your timing map right hand side to lower value ( 5 degree is ok unless you have horriable AFR). start full throttle in lowest boost, I usually start at 0.5 bar, adjust K value to reach 12 AFR, let throttle off if anything worng, repeat until you see whole rev range 12 AFR (just like your fuel map), fine tune your K value + latency combination, try different combination to see which works the best.
If you have a almost perfect K value, set your fuel map right hand side to 0.5 AFR richer than your target AFR, also lower some more timing on the fuel right hand side, set your boost controller to max target boost, do it in 3rd gear, let say you want 11 AFR at 20 psi, bring up the boost to 20 psi at this stage, set 10.5 AFR on your fuel map, watch your AFR gauge on accelerating, while it hit 20 psi and your AFR didn't reach 11 AFR, either your K value is too low, or your fuel pump cannot supply enought for your flow, if AFR at 20 psi is richer than 10.5, that is a good sign, your fuel supplying is up to the task, lower your K value until you see 10.5 AFR, once your have reach this point, do not change your K value and latency here after, check TP reading in "input tracer", if your max TP is 90, input 90 in the 15th column of your load scale, let 16th column be the overboost protection.
fine tune your fuel map to 11 AFR at 20 psi and any point in between 7 to 20 psi, and also fine tune your ignition map.
For a correct TTP min map, take the stock TTP min as a base map, in all 16 column, stock value x 370cc/800cc, then you will have a good TTP min map, leave the TTP max at all 255.
Sometimes you need to tune the TTP min at low end rev, apply light brake to force engine rev lower than idle rev 800 rpm, this will force your AFM signal lower than 1.040V, use the TTP min map to supply enought fuel to avoid engine stall at low rev.
A on-dash fuel pressure gauge will tell if your fuel pump can supply enought fuel.
If you do not have one, end up you will mess up your K value, will trying to use a higher than perfect K value to reach your target AFR, and make your low end richer than your target.
A re-circulate BOV will show the real AFR while throttle off just after boost, but most owner love the BOV sound, it will make latency harder to spot on.
If tuning step by step boost up ....5psi, 10psi, 15psi, 20psi, 25psi...end up you will found that your load scale not match with the hi boost, you need to scale it all over again, and mess up the tune done good on low boost.
There are many trick to get the tune perfect, like tuning the VQ map, but it will be too difficult for a new tuner.
Hope my $0.02 make you feel easier to tune with.
Wish you good luck.
