tuning a Blitz BOV
Ace
Car: S14
Ok the instructions came in japanese, so no help there. How do you tune a bov. I suspect it deals with the screw on the top of the bov. Help me out fellas.:help PS I will be running stock boost for a couple months, then I will bump the boost up to 13psi.
SpeedRacer1
Car: 1990 240SX, G35
Basically you want to turn the spring until its holding the boost (7psi) when you floor it but releasing the pressure when you come off the throttle. Easiest way to see if its holding the boost or leaking it is to hold your hand over the hole and have someone rev the engine. The only thing that sucks is if you want to go back and forth between 13 and 7 psi you need to adjust the BOV constantly.
godspeed
if you want to scan the book i can look at it for you, it might take me a couple of days to translate it, but i should be able to do it, i did it for an f-con instructions for an sr20det...email it to [email protected]
Ace
Car: S14
Thanks thats all the info I needed.
