evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Jun 24, 2010 10:10 am
you never "tune" your stock ecu, all the "chips" replace the "chip" in your stock ecu, and the code hacks like nistune, zemulator, romulator etc all repalce the stock chip with a stacked or remote programable board or box, none of them actually "tune" your ecu, they replace the internals and in some cases allow for active tuning of said replacement
and your car is runnign rich because of the missing O2 sensor, add a couple of O2 bungs in those test pipes and your computer will dial back the fuel a bit, and having no cats makes a car smell richer than it is as there is no cat to burn off the excess fuel which there will always be some
