tuners
240sxbobbis
Car: owned a ca18det s13 two of them, jeep wrangler, suzuki gsxr600, 86 mazda rx7, and a y33.
well the question is simple has anyone tuned their safc 2 in their ca mobiles. what tuning is needed for it how did you set them pics mods
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Well I didnt understand much of that, but what exactly are you tuning for? Do you have any idea how to tune the safcII or are you needing help getting started? What is done to the car?
240sxbobbis
ok sr turbo fmic blitz boost controller stock injectors stock fuel pump well i really want to know how to tune it up a lil
Masterdebater
Car: 1989 nissan 240sx coupe
u need to get a wideband reader so u know ur AFR's. the afc is used to control how much fuel ur feeding in so if u look at the HI MId and LOW throttle points u can see u can add and subtract fuel at different rpm points. u dont wanna do that without knowing where ur AFRs are standing right now
r34 gtr
Agreed, however you can just go to your local dyno and tune for an hour or two using their wideband. Itll save you from spending a little extra money if you dont want to shell out $195 for an LC-1 or something. Either way youll only need it for a few hours.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
When you say stock fuel pump, you aren't talking about the stock 240sx pump, are you? If so replace IMMEDIATELY.
240sxbobbis
i am in the process of doing that crad loot is kinda tight over here on these ends lol but the info is helpful guys what good widebands are out there? or what would you suggest?
r34 gtr
The Innovate LC-1. It can be had for under $200 and its the heat. You'll need a laptop though.
Masterdebater
i want the innovate...for some reason though my wires for the o2 sensor were clipped so ill have to wait on that haha
r34 gtr
How would that keep you from installing the LC-1? all these widebands use their own wiring harness and stuff...
