what's duct tape tuning?DaveVQ wrote:the 00vi is the IM from the 5th gen maxs, there is a write up about how to do it here, a good place to look for the 2000-2001 maxima UIM (upper IM) is on car-parts.com
and no for a simple AFC you do not need a laptop. it just taps into the MAF signal and makes adjustments.
Of there is always the duct tape tuning, but thats a different story and a bit risky. who wants to ask what duct tape tuning is?
Edited by maxhopper97
One piece design. It depends on which parts you want to get as there are many ways to do this. You can go as far as getting the upper and lower IMs, fuel rail, injectors, and throttle body or stick with the bare essentials and get just the upper IM, flip the lower IM 180 degrees, port it yourself, and make an adapter for the stock throttle body.flyboy367 wrote:what do those manifolds usually sell for? im assuming its a 2 piece design
Duct tape tuning involves using a small piece of duct tape and covering a very small portion of the hole of the MAF wire itself. It helps to rich out things a bit, but its not easy and very risky...cause if you cover too much it riches out too much. I will look for pictures of it....allensteiner wrote:
i see you got edited...did you make another reference to the org?
Nope, don't have to do that. Flip the lower IM 180 degrees and ghetto PnP it.DaveVQ wrote:he said one because there is two ways to do it....
one way is with 5th lower and upper IM but then you need 5th gen injectors and some other things, but it requires retuning
the other way is 4th lower and 5th upper and you can keep your injectors and there is no need to tune. you just have to weld and redrill the 4th gen lower IM
I had adapters for the IACV and TB. Forgot to mention those. You can find a guy on the org who makes them.flyboy367 wrote:ok so i get the upper 00-01 intake manifold, flip my stock manifold and bolt it up. what about the tb does everything stay the same? thats sounds better. otherwise for $600 for an intake manifold id rather throw some spray on.
anyone have pics of this fiasco?
Postwhoring is generally looked down on there, especially when getting to the 15 posts necessary to start a thread of your own. My advice: hit up the Members Rides section and start posting, "Nice whip" or something to that effect in 15 threads.flyboy367 wrote:thats gonna be tough since i registered there made a post saying high and then was banned.
