TUNER LUG NUT SIZES FOR OUR COUPE?
All things Altima Coupe.
BLKmomba1
Car: black 08 altima coupe
so i kno this is probably a dumb question... but i tried searching it everywhere and came up with no direct answer. i have my rims in storage till spring. and of course the chunky a** lugs that come with the stock hubbie rims wont fit and would look horrible on rims. i need tuner lugs. so i spotted out some nice lugs that would go nicely with my rim choice but i dont kno if there is a universal size or a specific size we need. i dont have the time to take the rim all the way to the tire shop just to find out.... any one know and me if this is dumb but i gotta kno before i miss out on these lugs! thanks nico fam
Bump this thread, i figgured it out... But it b cool to see posted detail pics of everyones rim, break, lug and center cap choices anyway
Modified by BLKmomba1 at 4:22 PM 11/18/2009
SniperJoe
Car: 2008 Nissan Altima Coupe 3.5 SE CVT, Premium, Tech, VDC.
I believe that the lug nut size you are looking for is 12 X 1.25
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
BLKmomba1 wrote:lugs that come with the stock hubbie rims wont fit and would look horrible on rims. i need tuner lugs.
Quoted for emphasis to anyone else happening upon this thread. It's really important to get lug nuts with seats that match your wheels.
dauer93
Car: 07 Nissan Versa Hatch
So im in this same predicament, i have rims and now that winter's over i want to put them on, but stock lugs wont fit, did you go with the 12x1.25 lug nuts?
and just a side note, did you happen to have to get centric rings for the wheels?
dauer93
mrodrig2
12x1.25mm is the correct thread pitch for the lug nuts.
Whether or not you need centering rings is wheel specific. If it is a hubcentric rim with a bore that matches your car's then obviously the rings are not needed. In any other case it is the safest bet to use them even though some will argue it's not 100% necessary in all instances.
elfenlied8
Car: Altima Coupe 2010 2.5S
usually when you get tuner lugs, hubcentric rings arent really needed, but if you feel some sort of wobbling at high speeds then hubcentric rings should be used.
