Tuned!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I finally got some time with the laptop and did some datalogging yesterday evening. (On desolate country roads out in the middle of nowhere for all you "high and mighty" types.) Rewrote the INJ map a few times trying to get a dailed-in tune and HOLY $HIT is it fast! The thing runs smoother, sounds totally different, and has way more power. After I rewrote the map for the first time logging, I got on it from first and the thing got to redline so fast that I bounced it off the limiter. I'm usually pretty good about not hitting it, but the thing came up so fast that I wasn't expecting that kind of a difference.
I'm going to fill in the gaps and smooth out the bumpy spots in the map today and reload it tonight. I still think I"m running rich in areas, and might pull the fuel back even further with a little help from cdorhout.
rustbucket
Car: '90 s13 RB25DET SII
I thought you were more mature than that! Driving around like a bat out of hell on backroads. You could have hit an innocent squirrel.
Congrats!
Shocker
Car: 89 240sxHB rb26/30
congrats man!, I do hope you have a wideband to stare at while doing this..
kjlindgr
Congrats! Now post vids.
Darius
Wideband feeds into the datalogit at 20 times per second so no need to stare at it. Also have EGT from cylinger 6 in there too. This system has been the best investment I've made in the car to date!
hmmmm I'll have to borrow the camcorder from work and shoot some stuff tonight. Maybe I can find some trouble.
kjlindgr
Hmmm...trouble. I like the sound of that!
I had a datalogit on my RB26-S14 back in the day and I agree. Best investment for the PFC.
240z4u
Car: '95 Nissan 240SX
Darius, I have the same tuning aids. Wideband fed into datalogit and EGT on cyl 6.
My car is poorly tuned, but was worse before. I am going to hit up the dyno.
Congrats man, have someone ride with you to watch so you can keep your eyes on the road. Much less stressful that way for me.
Evan
Carl H
i'll have a datalogit in my paws next week, cant wait to get the afrs out of the 9's on full boost and spool, nothing but power to be had right now.glad to hear it man, perhaps we should start an online map collection for modded rb motors?
Darius
It would be good to have a map resource, but could be dangerous. If I were to use someone else's map and they have their timing very advanced, then I might detonate the piss out of my motor the first time I load the map.
Once you get the FC datalogit, there is a yahoo user group that has files of conservative baseline maps that you can use plus excel spreadsheets to help you quickly calculate injector correction values based on desired AFR's and other goodies.
Since I'm running lower compression, I'm going to advance the timing to see how much I can advance it before it starts to knock up top.
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
To save anybody running PFC and high boost (16+ psi) some headache.
The base IGN in the PowerFC is pretty aggressive. So when I was boosting 19psi it was detonating badly. I had to pull timing back 3 degrees in all WOT/high rpm cells.
Carl, I think you're running the same turbo I am (GT3076R), so beware of this when tuning. Back your timing off on the top end, and slowly put timing back in. I could have hurt my motor pretty bad if I didn't figure it out when I did.
Carl H
strange that you were getting detonation, highest ive seen is 30 on a hot day at 18psi, but then again im running the 20 timing maps which have much more ignition in the low down to midrange but not as much i the top end.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
is this the apexi datalogit or is it the austrailian one. cause im getting the apexi datalogit software for my pfc here in a couple of weeks so i can finally tune cause apexi it about to release there tuning software for the pfc in the US here in a week or two. and i already had mine on order for the past 3 weeks now. oh and congrats daruis
OpeLok
Carl H wrote:strange that you were getting detonation, highest ive seen is 30 on a hot day at 18psi, but then again im running the 20 timing maps which have much more ignition in the low down to midrange but not as much i the top end.
you running more timing than this?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Darius,
Congrats man!
Videos or BAN!
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
congrats!
of course vid footage
lucky7
Car: 97 RB25 S14
i want a bigger turbo.
good news man. now you get 2 months before the snow flies.
forksquared
Car: 91 Nissan 240SX coupe
98 Subaru Forester S (New DD)
if you are running the gt30 i want to know what kind of power and how responsive it is. im looking at getting that turbo when i get my rb25
