Tuned by John Reed @ Torquefreaks, I give u my 300HP 240sx
civicsi2
John is the man.
Mod list:Exterior Modifications: - Silvia front-end, triple project headlights - 5Zigen FN01R-C's, bronze, 17x7 front, 17x8 rear - Falken Azenis Sport tires, 225/45/17 front, 245/45/17 rear
Suspension/Brake Modifications: - D2 32-way adjustable coilovers, 9kg front springs, 7kg rear springs, camber plates - Tein adjustable T/C rods - Adjustable rear upper control arms - Z32 26mm aluminum front calipers, BMI cross-drilled/slotter brake rotors, Heavy Throttle stainless lines - Nissan Z32 VLSD
Interior Modifications: - Autometer dual gauge pod - Defi Link Control Unit VII -Defi Link Gauges, 52mm black, Imperial Unites (EGT, Water Temp, Oil Temp) - Greddy Boost Gauge - AEM 52mm Wideband UEGO Gauge - Alpine Head Unit, Infiniti front speakers, Alpine rear speakers - Battery relocation to trunk, Optima red-top battery - Bride Brix drivers seat, S14 passenger seat
Engine Modifications: - Redtop SR20DET motor - SPEC stage III clutch - GReddy V-SPL FMIC - GReddy 3" downpipe - Enjuku racing hotpipe w/ GReddy Type-S BOV - S15 multilayer exhaust manifold gasket - Braided stainless turbo lines - TurboHoses.com silicone hoses/T-Bolt clamps/Spring-loaded T-bolt clamps - Walbro 255lph high pressure fuel pump - Garrett GT2871R .86 a/r turbo - Nismo 740cc fuel injectors - AEM Engine Management System, GM 3bar MAP sensor, GM IAT sensor - Koyo Aluminum Radiator - Dual 12” flexlite fans - Gm Boost controller - HKS Hi-Power 3” exhaust w/ test pipe
Most recent pic.
slow s13
Car: cars, photo, music
what boost? others with this turbo have hit around 350-370 hp
civicsi2
16 psi. I still have stock head gasket, cams and manifold.
BaliLover
Seems a bit low, I got 314hp and 306ftlbs of tq with a stronger torque curve at 19 PSI on the smaller GT28RS.
What octane fuel are you running, you should be able to get more pressure out of that turbo safely. I believe Enthalpy got around 360hp from the same setup as you.
NismoS13T
Car: 1997 240sx (kouki)
That does seem low for that turbo and 16psi. Looks like a big t28 dyno graph.
highmilehatch
Good job on a clean buildup! Tasteful, clean, and powerful. I commend you. Have you considered upping the boost? It looks like you got the fuel system and management to handle it.
msaskin
Car: cars, computers, skiing, mountain biking
Nice to see some pictures of my old car
How is the exhaust on it? That's the one thing I always wanted to do (new exhaust).
To second what everyone has been saying, that does seem a bit low power wise for that HP level. Did John or any of the other guys at HPF have anything to say? (other than my quick tune on it sucked )
EDIT:holy ****! I just looked at your website...you did an absolutely freaking AMAZING job of restoring all the little things in the car (carpet, etc...).
~matt
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
yeah man nice setup you got there Where did you buy those rims for? know where I can get a good deal?
msaskin
got2b240 wrote:yeah man nice setup you got there Where did you buy those rims for? know where I can get a good deal?
http://www.importparts.com is the cheapest I've found (that used to be my car )
~matt
Nismo_Freak
Car: 89 Nissan 240SX
Wow... $2 cheaper than us hahah.
s13sr20chris
300 at the wheels on that setup is quite conservative. i(probably the only one) will give you props for being conservative and taking it slow. i do hope that when it has cams and head gasket you push it hard as the aem management should be able to get you some nice numbers.
quiksilvia
Car: 95 s14 se
its that honda in ur sig, takes from ur hp
civicsi2
msaskin wrote:Nice to see some pictures of my old car
~matt
Yeah they, though it was a POS with nice parts. they basicly gave me a nice list of everything wrong. 3 bolts in transmission. 2 others completely cross threaded. total of 5 of 8 bolts in transmission. missing bolt in transmission mount, bolts were just sitting for carrier bearing, rearend is shot. I can't believe it made it home. powersteering leaked, oil pan leaked, rear diffy didn't even have any oil. speedo just needed hooked up. all seat bolts crosstreaded. Turbo lines kinked. oil return line was crap. plastic fan was broke. Then the wiring mess. welded the exhaust to the greddy downpipe. I can keep going.
I feel real stupid for buying it but oh well, live and learn. You must have been drunk when you worked on this car or u just do horrible work.
civicsi2
quiksilvia wrote:its that honda in ur sig, takes from ur hp
Thats awesome. probably right. I'll make a new one when i have time.
msaskin
Ouch
Some things I was completely unaware of (seat bolts, etc.)
I had changed the rear diff probably 5K miles ago and never saw any fluid leak out...did they say what was leaking from it??? I also re-sealed the oil pan the day before you came to get the car, odd that it started leaking. Was it just a bad sealing job or some other problem?
Either way, you did an awesome job with it and I commend you for that.
~matt
