Oh, get a rom tune and a wideband...JYangS14 wrote:My tune is with an Apexi PFC, done on a dyno by a reputable tuner. I'm pretty confindent in the work the tuner does. I'm just ready for some more power now. Thanks for the answers.
JYangS14 wrote:A rom tune? I'd assume my current dyno tune with the Apexi PFC be far superior to any rom tuning? I already have a wideband, the innovate LC-1. I also already have Tomei procams, tomei valve springs, cosworth metal headgasket, arp head studs. I'd like more power now, but I don't want to change out my current turbo or rebuild my bottom end. Nothing too drastic. I was thinking an exhaust manifold and test pipe, but was told they don't make much of a difference performance wise.
kentuckyslider wrote:JYangS14 wrote:A rom tune? I'd assume my current dyno tune with the Apexi PFC be far superior to any rom tuning? I already have a wideband, the innovate LC-1. I also already have Tomei procams, tomei valve springs, cosworth metal headgasket, arp head studs. I'd like more power now, but I don't want to change out my current turbo or rebuild my bottom end. Nothing too drastic. I was thinking an exhaust manifold and test pipe, but was told they don't make much of a difference performance wise.
Sorry, I can't read, thought you said SAFC.....
If your Power FC is tuned with MAF you should be fine. Just turn it up 2lbs at a time and watch the wideband.....ou will run out of injector much past 18psi,,,.
