Tune Up?
SunLitSandMax00SE
Car: Silver 2006 Infiniti M35
I have had the M35 for about four years now and I haven't gotten a tune up since I bough it. I have put about 45k on it since then. I feel as my MPG is terrible. The status shows it at 16.4, but that has never changed. Will a tune up increase that and how much do people usually pay for one? Thanks.
GQM45s
Car: 2008 Infiniti M45 Sport Tech Pkg, Advance Tech Pkg, Mobile Entertainment Pkg
how many miles do you have on it now? Air filter replacement? spark plugs? do you feel your car misfires or anything like that? may need to replace the plugs - those are cheap repairs
SunLitSandMax00SE
GQM45s wrote:how many miles do you have on it now? Air filter replacement? spark plugs? do you feel your car misfires or anything like that? may need to replace the plugs - those are cheap repairs
131k. Yeah, I need to replace all of those. No misfires. Car has always run very good. Just the MPG is really bad.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
The plugs will help with mpg, transmission service for smoother shifting and fuel injector service, etc. on am M35 you should be getting closer to 20mpg city/Hwy combo driving! :gotme
bluedevil30
Car: 2009 M35X
265,000 miles
Just had dealer do trans fluid replacement, radiator flush, cabin filter and air filters for about $550. It was the only time Ive let a dealer touch my car (83K) for routine service. Dealer said spark plugs need to be changed at 100K.
06M4.5
Car: 2006 M45
I try to stay away from the stealers as much as I can.
I just got an oil & filter change, radiator & rear diff was flushed by machine. All for about $140.
I had to buy a qt. of matic S at the Nissan stealer for $13 (rip off) to top of my trans which doesn't need to be changed for another 10k miles.
I was able to order both drive belts (Goodyear Gatorbacks) for about $40 with shipping.
As soon as I get both belts I'll have them installed and will be finished with the maintenance at a price of less than $250
seymore4
Car: 2012 M56
Professional UPREV tuner
Absolutely replace the spark plugs. I've never seen a VQ35DE that didn't benefit from new ones even after only 30K miles (stock tune)
Nissan says that the OEM plugs are good till 100K and if you haven't replaced them then I'd venture to bet that they're still the factory plugs.. swap them out asap
PlatinumM35
Car: 2006 Infiniti M35
Tein H-Tech Springs
Slotted/Cross Drilled Rotors
Wagner Ceramic Brakes
22x9 Status Wheels
Rear Entertainment Aftermarket
15'' RE Audio Subwoofer
Infinity Reference Door Speakers
As others have stated, stay away from the stealership...save yourself the cash and set aside a little time to knock it out. Most of the maintenance is easier than it may seem.
