PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Thu Jan 02, 2003 12:58 pm
The FAQ says that Redline 75w 140 (i think... you should double check) is the best for the transmission and 80w 140 (i think) is the best for the diff. i thought this sounded a bit odd at first, but they do make the stuff. Its a bit more expensive than regular gear oil (because its a synthetic) but apparently it works much better. Good Luck.
