Chris92SE »
https://forums.nicoclub.com/chris92se-u42786.html
Fri Jan 30, 2009 10:49 am
I highly recommend you use NGK spark plugs.
I haven't discussed this specifically about the Pathy/Q, but with my Maxima (also a coil-on-plug) I have talked with a couple of Nissan Techs. They have told me that some other brands of spark plugs don't work well with the coil packs and over time can cause them to misfire. One guy told me over 1/2 of the Maxima he had with coil pack problems had Bosch spark plugs in them.
He also said in my Maxima, that I could use either platinum or copper, as long as they were the same heat range. I would just have to change the copper more often. Quite a few people in the Maxima community (especially VE30DE engines) do this. I don't know if I would in a Pathy/Q, just because the spark plugs are a lot harder to change.
As for your tune up, I would also check the condition of your belts.
