Fred D. »
https://forums.nicoclub.com/fred-d-u36717.html
Mon Jan 30, 2006 6:10 pm
I recently purchased a 1994 Q45 with more than a hundred and ten thousand miles on the OD. Today I was tuning it up to see if I can get the car to run smother. I went to Q45.com and read all of the information I could find, and performed a MAF cleaning with electric component cleaner, cleaned the three prong conecter and added dialetic grease, then I cleaned the TB with CRC TB cleaner, and added a can off BG44k to the tank. After all that it felt more responsive, but no smother. The car seems to shake some when it is in park or at a stop light. I have a list of things Im suppose to try, & should fix this shaking. It said on Q45.com to check this, AAC, TPS, CAS, O2 sen., Seafoam?, and the KS. I only have found information on MAF, TB, and fuel injectors, but the rest I've listed I dont know how to check them for problems.
