Tune up done car check engine soon light just came on
grip1968
Car: 2000 Nissan Maxima
I had a tune up done on my 97 q45 last weekend, and today driving to work my SES light came on. So I want to advance auto to check the code here they are P0305 & P0325 KNOCK SENSOR ERROR & MISFIRE ON CYNLINDER #5. I called the mechanic that work on my car and ask him did he used NGK plugs he said no he used BOSCH. I said why I told him to get NGK I dont care how much they cost. So I will be going to him tomorrow to change these plugs to see if this fix the problem with the misfire on cynlider #5. Now for the knock sensor code do I need to replace this if so I can have him do that while he changing the plugs, or are this is a common problem for q45.
Thanks
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
What did you tell your mechanic to use originally, NGK (OEM) or Bosch (VH killer)?
He has to change them out ASAP and not charge you for it if you said OEM NGK.
grip1968
I told him to use NGK, he said his parts person order bosch by accident, whatever I will be there tomorrow to get them replace. Should I have him change the knock sensor to while he doing the plugs.
qship96
Car: 1996 Infiniti Q45
Sure, should only cost another $1000 or so.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Regardless of the mistake of the parts guy, your mechanic should have known better not to use Bosch if he really knows Q45 AND to follow customer request. Hopefully, the KS code will go away once you have the OEM plugs.
mtzgr777
Car: 1996 Infiniti Q45 143k Silver/Black
Wow it's a good thing I read this. I'm planning on getting new plugs in a couple of days, and I was gonna go with whatever was cheapest....now i know NGK or nothing. Thanks again guys.
Modified by mtzgr777 at 7:24 PM 9/15/2009
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
NGK PFRG 5 or 6 only! 1.1mm gap.
mtzgr777
Ok maybe I'll just order it myself so the mech doesn't screw me over
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
He already did.
Order form Joe or http://www.sparkplugs.com
RTFSM before doing or especially trusting someone else to do anything on your car. You have to know as much as you can to prevent damage.
mtzgr777
Sorry, I'm new to this forum....who exactly is Joe and how can I get a hold of him?
Also, which of these is better for a '96 Q and why?
NGK GP platinum 7090 BKR5EGP .044" DOHC $3.15
NGK Traditional 2382 BKR5ES-11 .044" DOHC $2.89
NGK V-power 6953 BKR5E-11 .044" DOHC $2.89
NGK IX iridium 5464 BKR5EIX-11 .044" DOHC $7.83
Infinitiguy19
Hey unfortunately everyone who has tried the plugs listed above or even any other plugs has had real bad luck with there car (They had to get another one). Like for instance Unknown007 and the Q45 that I am currently parting out (STILL ).
So the ones you need are the OEM ones: PFR5G-11 (the hot type which are the ones I have and are fine for where we live).
Dealer part number: 22401-1P115
Price:
MSRP: $11.00
*IOS: $8.25
Cost to make: 5¢
*Infiniti Of Scottsdale with there 25% off.
jamm220
Car: 02 q45, 05 Q45, 98 GSR, 00 RL
02 Q and denso iridium has been just fine for me so far
mtzgr777
Lol cost to make 5¢
tfvesquire
Car: 1998 Q45
Price:
MSRP: $11.00
*IOS: $8.25
Cost to make: 5¢
*Infiniti Of Scottsdale with there 25% off.[/QUOTE]
Hi There:
I bought a set of these plugs for only $25.00 for all 8. If I am able to look up the seller, he usually runs a listing on Ebay from time to time. $8-11 dollars per plug is highway robbery IMO. Just do a quick search on Ebay for that plug number and you should find him. **Also, the 95-99 Nissan Maximas and I30s also use the same plugs. I don't know if the "ghost code" for the KS will go away just from changing the plugs to the factory correct ones, but that would be nice if you get lucky.
Depending on how many miles are on your KSs you should change them out if you plan on using the car for a daily driver. There are plenty of great write ups here on the forum for you to change them without having to remove the plenum. Save yourself the expense and potential leaking plenum gaskets/hoses and don't let your mechanical tackle this. Replacing these will save you money through more mpgs as well as less wear and tear on your ignition system.
Good luck!!
Ted
mtzgr777
tfvesquire wrote: Replacing these will save you money through more mpgs as well as less wear and tear on your ignition system.
Knock Sensors have something to do with your ignition? Could that be why my car takes a little bit to start up? It goes on the first turn of the key, but its not as fast as I would like it....
qship96
loystock wrote:Regardless of the mistake of the parts guy, your mechanic should have known better not to use Bosch if he really knows Q45 AND to follow customer request. Hopefully, the KS code will go away once you have the OEM plugs.
Sparkplugs have NOTHING to do with knock sensors........must test and replace defective knock sensors and their harness to clear codes and restore designed performance.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
mtzgr777 wrote:Lol cost to make 5¢
Platinum is cheap!
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
Ted, Please let me know the result once you have installed the new plugs you bought from eBay. I hop[e they are the real OEM and not clones from somewhere else. When I was in the Middle East, they have lots of cheaper clones there too. Once I have to replace headlight 3 times (replacement under warranty) unti lthe local Toyota dealeship realized they have a bunch of imitation headlights. The assembly and box look original, but only found out it was a fake when they dissected the headlight.
Again please let me know the outcome as I have at least 2 carss needing sets of plugs next year. That will be a huge savings if they are for real.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Joe has sales at $6 per plug.
qship96
Even at $10 per plug, whats $80 over their lifespan of 60,000-100,000 miles??
One tank of gasoline will cost more than that soon, and only lasts 300-400 miles!
grip1968
Ok I had my mechanic change the plugs to NGK platinum PFR5G-11 he erase the codes also to see if the will appear again nothing yet I will keep everyone informed...
tfvesquire
Car: 1998 Q45
Sorry for the confusion. A KS merely adjusts the timing to compensate for lower octane fuel or other fuel sustem related issues to prevent knocking and damage to the engine. It can also have an effect on the timing/frequency of the coil pack firing -- that is what I meant by it can affect your ignition system. Your problems with your car being hard to start could be a number of things: dirty TB, clogged air filter, bad cam or crankshaft sensor, etc.
tfvesquire
Car: 1998 Q45
loystock wrote:Ted, Please let me know the result once you have installed the new plugs you bought from eBay. I hop[e they are the real OEM and not clones from somewhere else. When I was in the Middle East, they have lots of cheaper clones there too. Once I have to replace headlight 3 times (replacement under warranty) unti lthe local Toyota dealeship realized they have a bunch of imitation headlights. The assembly and box look original, but only found out it was a fake when they dissected the headlight.
Hi there:
In response to your request, I installed these plugs I bought last year and they have now about 2000 miles on them with no problems. Came in the correct NGK boxes and from a reputable seller. I did a quick search on Ebay last night and was shocked at how much these plugs have gone up in less than a year ($90 for set!!). I will try and contact the seller I used to see if he is still selling a set of 8 for a reasonable price and let everyone here know either way.
Thanks!!
Ted
mtzgr777
Great! Thanks.
