tune ecu
hers1via
Before I install this 440cc in I was wondering if anyone know where I can send my ecu to be tune. Looking for another remedy for the safc. Thanks
rico05
Car: 1992 RMS13 w/ CA18DET
You can do it yourself. All you need is LiveEdit (google search it), a 28 DIP socket, a burner and a spare EPROM. Most shops will charge you well over $200, in what totals about $75 in parts. Do a forum search on the topic and you should find all you are looking for. I did mine (well, a buddy burned the actual EPROM for me as I am too cheap to buy a burner), and it is really silly easy to do.
Also, check out http://www.ztechz.net/ It is for the Z32, but the process is the same.
MasterZenki
Car: 1990 240sx
burner?
mat180
Car: nissan
arare the coeds the same for a ca as z32? or where can i find out which codes are what?
ie. speed limiter on the z is 7fb4, what would it be on a ca?
or does this program provide the code and code functions?
