BONUS. -----
Picked up this bike on saturday. Turned into a bobber in a few hours lol.
I dont have any pics yet but yes i did. I did this front end a few months back.OutToWinPAHC wrote:not bad but please say there is more than one tube now
Well with the work he went to, he could have built in a crumple zone, he could have even just used smaller tube, I've seen tube fronts that should be superior to the stock front, but that would still crumple if they had to.liquid_cool wrote:proves you can replace anything with a welder and a sawsall!...i would have cut the front off a donor car myself..and he's correct about the crumple zone.
But, those are higher stakes builds, inherently. It makes more sense to really do anything possibly for rigidy, for them.Razi wrote:That's how Dai and other FD drivers have their cars built.
Sturdy stuff for areas that have to do with the car's structure, and thinner stuff for things that are there to just hold up bodywork.
Daigo's stuff is even weaker. Maybe too weak.
mechanicalmoron wrote:But, those are higher stakes builds, inherently. It makes more sense to really do anything possibly for rigidy, for them.Razi wrote:That's how Dai and other FD drivers have their cars built.
Besides, top one looks perfect, how it's braced makes a lot more sense than what I saw of OP's (friends). The rails are connected to the towers by heavy stuff, but there's a much smaller bar out front that will crumple and slow things, and probably save more behind it. Specifically, he could knick a corner (pretty hard) and it wouldn't damage the heavier structure, the diagonal tubes are what gives the frame it's strength, and they're tucked in He also left some more fender structure in place. In OP's pictures, the corners will do devastating things to the frame, if you hit them.
Just imagine if he crashed that front end, in the way he originally crashed it. It'll total the car where it needs either a donor front welded on at the firewall, or a whole new shell, I'd wager. It just looks like the one you posted was more carefully designed.
But I could be wrong, I've never built, or driven, or wrecked, a car with a tube front. I have wrecked a normal front end (not a 240), I hit a pickup, and the hood and core support crumpled and saved the frame, it's still being driven in the same shape.
*edit* he either botched it before a finial (and safer for the car's welbeing) product, or else there's two cars there. He originally had it mocked up with replacement silvia parts, and then with buckets and changed where a tube meets the strut towers, and then added a bunch more and did some cutting/bending. The finial one pictured looks a lot better, but the first looks like a disaster. And it really looks like two cars.... Or else he's VERY indecisive.
Until the very end I was planning on inserting cool story bro herepepesilvia wrote:dude, daigo saito is an awsome drifter. saw him a formula drift last year and he got snubbed. somehow i dont even think he came in top three, even though he was close. even my girlfriend new it was BS. I think formula drift is rigged. but still fun to watch........ anyway, yeah, i worked close to that community auto center but never have the balls to go check that thing out. who knew it had a supercharged LT1 under the hood? hahaha im very impressed
my bad. i may have a touch of adhdOutToWinPAHC wrote:Until the very end I was planning on inserting cool story bro herepepesilvia wrote:dude, daigo saito is an awsome drifter. saw him a formula drift last year and he got snubbed. somehow i dont even think he came in top three, even though he was close. even my girlfriend new it was BS. I think formula drift is rigged. but still fun to watch........ anyway, yeah, i worked close to that community auto center but never have the balls to go check that thing out. who knew it had a supercharged LT1 under the hood? hahaha im very impressed
liquid_cool wrote:i thought long and hard on this build and the structual safty behind it....unless the front tubing is connected in someway with the inside tubing of the cage..this could be a risk for the driver as the give point will be behind the shock towers...even if the tubing was connected to the cage on the inside of the car, it could cause searious damage to the driver as the front section is to ridgid..the brain could be forced forward on a head on impact or the collor bones broken due to the harness.. possibly even both..the forces have to travel somewhere..think of it like a golf ball vs a woofle ball..better yet..a pickup vs a mack truck..or a smart car vs a mack truck...in an accident, the driver of the truck will be hert and probly on the way to the hospital...but the driver of that smart car would be dead couse the body has NO give points ...the shock of the impact alone would kill him...please think a little more on your desighn..just becouse someone jumps out of a plane with no shute, doesent mean you should follow..
The tubes themselves are not going to crumple the same way. It doesn't matter if they break away a bit, they reduce the crumple area. If you cut a soda can in half and weld a swingset in place of half, it's going to have half as much cushion....jefferz wrote:liquid_cool wrote:i thought long and hard on this build and the structual safty behind it....unless the front tubing is connected in someway with the inside tubing of the cage..this could be a risk for the driver as the give point will be behind the shock towers...even if the tubing was connected to the cage on the inside of the car, it could cause searious damage to the driver as the front section is to ridgid..the brain could be forced forward on a head on impact or the collor bones broken due to the harness.. possibly even both..the forces have to travel somewhere..think of it like a golf ball vs a woofle ball..better yet..a pickup vs a mack truck..or a smart car vs a mack truck...in an accident, the driver of the truck will be hert and probly on the way to the hospital...but the driver of that smart car would be dead couse the body has NO give points ...the shock of the impact alone would kill him...please think a little more on your desighn..just becouse someone jumps out of a plane with no shute, doesent mean you should follow..
The points that the tube make contact to the chassis are not fully welded. Its to ensure that it crumples. I love how everyone on the forum is a know it all. When he crashes again Ill show you the pictures lol.
the point about safty equipment you dont realize is (It only need to work perfectly one time!)..if it is desighned not to save the driver from harm..but to save the car insted..then it has all ready failed!..minor accidents are fine for a crash bar..but its the what if's you plan and build for..ive done over 20 minor crashes and put my ride back together..no big deal..but every major crash..i get a new shell for safty..just my opinion, i could be wrong..but i doubt that i am in this matter.jefferz wrote:liquid_cool wrote:i thought long and hard on this build and the structual safty behind it....unless the front tubing is connected in someway with the inside tubing of the cage..this could be a risk for the driver as the give point will be behind the shock towers...even if the tubing was connected to the cage on the inside of the car, it could cause searious damage to the driver as the front section is to ridgid..the brain could be forced forward on a head on impact or the collor bones broken due to the harness.. possibly even both..the forces have to travel somewhere..think of it like a golf ball vs a woofle ball..better yet..a pickup vs a mack truck..or a smart car vs a mack truck...in an accident, the driver of the truck will be hert and probly on the way to the hospital...but the driver of that smart car would be dead couse the body has NO give points ...the shock of the impact alone would kill him...please think a little more on your desighn..just becouse someone jumps out of a plane with no shute, doesent mean you should follow..
liquid_cool wrote:the point about safty equipment you dont realize is (It only need to work perfectly one time!)..if it is desighned not to save the driver from harm..but to save the car insted..then it has all ready failed!..minor accidents are fine for a crash bar..but its the what if's you plan and build for..ive done over 20 minor crashes and put my ride back together..no big deal..but every major crash..i get a new shell for safty..just my opinion, i could be wrong..but i doubt that i am in this matter.jefferz wrote:
