Jz32 »
https://forums.nicoclub.com/jz32-u172885.html
Sat Nov 20, 2010 7:04 pm
hey guys im new to this site but not to the Z32 ... i have a 90 2+2 with 198,000
i just finished dropping in a jdm tt motor and trans ... and for the record... i pulled both the motor and trans through the top with everything attached P/S, alternator, and A/C... with the tt being dropped in the only things i took off were the started which i let hang by the wiring harness and the A/c... im not runnign A/C so i dont need the compressor. while the engien was out i replaces all the injectors, fuel lines, plenum gasket, EGR delete,AIV delete and i also got rid of the carbon canister. pulling the NA motor only took about 2 hours tops with BSing for 30 min lol.... dropping in the TT took about the same.
now heres my problem.... before i dropped in the tt i replaced the wiring harness and had to splice in a couple connectors (CAS and cam shaft position sensor on the passangers) because those were corroded and cracked. eberything loks like it should... i do how ever have 3 unplugges wires... im guessing 2 of these are for OEM boost sensors if im not correct...they are on the plenum to engine block mount brackets? and theres another plug along the driver side by the fuse box. a gray plug and red plug, but i also have an extra with nno idea where it goes to..
after i bolted everuythign up, i connected the battery but its as if there is no battery, theres power to NOTHING,,, if anyone has had this problem doing the swap or even not,, im just lokoin for someone to point me in the right direction to look for problems... so im lokoin for why the Z has no power, an dcould this extra plug cause the car to be dead... id appericiate any help at all thanks guys..
