marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Tue Aug 23, 2011 8:35 pm
The transmission housing is different between the TT and NA. The NA housing is thicker inside, so to convert to TT, it needs ground. Then a shim is needed to move the starter out to mate to the TT flywheel. So the NA starter can be used on the TT conversion. The same starter can be directly bolted to the TT transmission since it's casting is different.
