TT hose question
Corvidae
Car: 1993 300ZX (TT / auto)
I've had my 93 Z32 TT in the garage all winter with a blown turbo. Due to financial and personal reasons, I haven't been able to finish the turbo swap until now, but I have the new turbos mounted and ready to go. My only concern at this point is this hose; it was pretty worn and cracked, so I pulled it off to replace it, except I can't find a replacement hose:
* Is this a special hose? If so, does anyone have a part number to order it?
* If it's just a regular vacuum line, what size? I can't get 3/8" line over the valve (the one that threads into the plenum), and any larger line will have problems with the hard piping on the other end.
* Is the driver's side line the same as this one? (it looks like regular line to me, but I haven't pulled it off yet)
Thanks in advance.
mrmoose
Car: 91 300zxtt
It's just a coolant hose so any fuel line will work.
Corvidae
Any idea what size? The valve and the piping appear to have different diameters.
minus1
Car: 1990 300ZX TT
It looks like it is part of the PCV system.
http://www.courtesyparts.com/300zx-part ... 4_891.html
These guys are selling it for $18
Another option: unthread that piece, runs down to the hardware store and find a threaded ( probably brass) part with a smaller diameter nipple so you don't need to buy an $18 formed hose.
Or, unthread it and see if you can force it on with the piece off the plenum the rethread it in before connecting the other end.
mrmoose
Car: 91 300zxtt
Ha ha my bad I was looking at the turbo coolant hose. Not the missig one. He is correct pcv, any automotive hose should work. I think I used 5/8 heater hose for my car...
minus1
Car: 1990 300ZX TT
I was just looking at z1 and they sell all of the PCV hoses for 7-15
