NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Sat Jun 24, 2017 6:13 am
The other piece of advice I will give you and EVERYONE on this forum will agree with is that you MUST buy quality components for your rebuild, this means OEM or better. For gaskets, belts, accessories, wiring you should go with OEM except the head gasket, there is lots of contention on this subject as to whether the MLS or OEM are best, you should do your research on that one. Pistons, rods, rings, valves, and other internals will depend on your HP goals, if you ever plan on going big-turbo then I would suggest you invest in the good stuff now. MOST IMPORTANTLY, get the machine work done by someone that knows these engines!!!! the machining process, though not different from many other high performance engines is something that a SBC builder will likely screw up. The tolerances on this engine are much tighter than most American engines and required a torque plate for bore work. I searched for months to find the one shop in the Houston area that does all of IPP's engines and I could not have been happier. Lastly, if you go to the machine shop and they don't ask you for your pistons, rods, rings, and bearings, even if they aren't actually assembling, you should turn around and walk away.
