TT CONVERSION SPEED SENSOR QUESTION
drape123
Car: J30 94, REAL CAI W/POPCHARGER, ECU-Reflash. (the DD) - 95 S14 KA-T Fully built gt35r@28psi when i ge
hi, i got a Infintii J30 with a jdm VG30DETT conversion installed i had a question about the speed sensor, are they different between the VG30DE and the TT? because it seems that its about 20mph over what it should be reading. i hear this could be because of the differential? is there any way to fix it? i hear the J30 is similar to a NA 300zx.
TIA!
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
drape123 wrote:hi, i got a Infintii J30 with a jdm VG30DETT conversion installed i had a question about the speed sensor, are they different between the VG30DE and the TT? because it seems that its about 20mph over what it should be reading. i hear this could be because of the differential? is there any way to fix it? i hear the J30 is similar to a NA 300zx.
TIA!
Speed sensors are specific to the differential, not the engine. Well, actually, it's the pinion gear that's specific to the differential. The speed sensor is specific to the car's dash itself.
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
the j30 has a 3.90 rear gear and the TT 300zx has a 3.70. I dont know if the tt diff will bolt up because it is different than the 300zx na and the j30. The rear pinion interchanges and if you can not find a tt gear than you can use a 97 up q45 gear set (3.70). Good Luck!!!!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I believe the short snout R200 and short snout R230 share mouning points but I believe the driveshaft and output shafts differ, so changinf the gear ont he speed sensor would be the way to go
240Z_Master
Car: 1971 Datsun 240Z
TIA!
The Z32 diff is a R230 unit and the J30 is a short nose R200. Best way is to pull out your speed sensor on the transmission, and look at the color of the pinion gear. Mine is red for my gear ratio.
Here is a chart for Nissan pinions... I wish I had part numbers for the pinions but your local dealer should be able to help you find the pinion.
Yellow 16 Tooth 3.364.1Black, 17 Tooth 3.545.1Blue 18 Tooth 3.70:1White 19 Tooth 3.90:1Red 20 Tooth 4.11:1Purple 21 Tooth 4.38:1
