Hey all. I am seeking recommendations on a clutch. I need something that will hold 500 or so HP but I want it to be as streetable as possible. I know that can be a tricky request as the pressure plate stiffness has to go up significantly with higher hp ratings. I have no experience with the z32 side of things only with Miata’s. So your input on which has the best ratio of clutch feel to grab is important.
In case your curious, this is for a miata with ls1 and gforce z32 trans adapter.
