evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Aug 02, 2010 10:13 am
nothing just bolt up to a VH, thats one of the reasons they aren't more popular, that and they are overengineered and have little to no aftermarket support
the TT flywheel will botl onto the crank ...I believe, but you have to accomodate for the added thickness of the trans adapter plate or your input shaft will have no support and things break, this means you need a spacer for the flywheel and pilot bearing as well
Z axis, as opposed to X axis and y axis....x and y are up and down left and right, z is in and out
