TT Automatic transmission shifts?
izmyttz
Car: 1990 300zx TT-White,
My TT with automatic transmission is shifting around 7,000 rpms or later..sometimes it hesitates and wont shift at full throttle..i have to let off and then punch it again..any ideas?
deknick
Car: 1990 JDM Fairlady Z TT,1990 USDM Z32 N/A, 1994 Infiniti Q45
are the USDM transmission's like the JDM ones, where you can switch it between, power, normal, and hold modes?
phreeek
Car: 1991 300zxtt
Not on mine. Just O/D on and off.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if there has been no recent changes like a remapped ecu then you might need a rebuild, sounds liek the modulator is sticking or not working and I don't think it's adjustable on the z32
evildky
06 Nissan 350Z GT
and I assume you already checked the fluid?
(car warmed up, shifted through all the gears, then place the car in neutral and pull the e-brake then check fluid while on flat surface)
izmyttz
evildky wrote:and I assume you already checked the fluid?
check the fluid with the car running or off? and after i run through all the gears..what am i looking for? low fluid level? thanks
