TT A/T ECU with Manual trans?
labcoatmonkey
Car: 1991 300zx JDM TT I miss u 01 alty
Hey Im sure this has been asked MANY times before and im sorry for the ignorance but ive been trying to find a straight answer for a while. I have a TT A/T ecu on a M/T tt, what needs to be taken care of in order for proper timing to take place? I read that the neutral switch (y/l) wire running through the relay box has to be grounded otherwise the ECU will set the timing to 25 deg btdc and cause loss of power and other wacky things. Is this true? Can I run an a/t ecu with a manual trans and not have to worry about switches causing timing retardy?
z32pilot62
Car: 1990 300zx N/A A/T (Sold)
1990 300zx 2+2 N/A A/T-M/T
1972 Buick Skylark Custom
1970 Chevy Blazer (Sold)
1977 280z (Sold)
1991 Civic Dx (Beater)
labcoatmonkey wrote:Hey Im sure this has been asked MANY times before and im sorry for the ignorance but ive been trying to find a straight answer for a while. I have a TT A/T ecu on a M/T tt, what needs to be taken care of in order for proper timing to take place? I read that the neutral switch (y/l) wire running through the relay box has to be grounded otherwise the ECU will set the timing to 25 deg btdc and cause loss of power and other wacky things. Is this true? Can I run an a/t ecu with a manual trans and not have to worry about switches causing timing retardy?
Get a chip for a manual and it will fix it, thats what my NA is running.
txQ45
Car: 91 300zx TT
google 300zx ECU eprom..
The best is listed first
labcoatmonkey
so the Z1 eprom is the best? Or can I just get the little chip and flash it and tune it with the same maps?
robomatic12
Car: 1990 300ZX TT
The auto ecu should run the manual car no problem. You can't run a automatic with a manual trans ecu.
What you need to do is complete the neutral safety circuit which will allow the car to think it's in Park or Neutral. It just won't start otherwise. But now your car will start with the clutch out, watch out for jumping into things if you aren't paying attention starting up.
labcoatmonkey
I need to upgrade to a better eprom anyway this one is a 3 dollar chip heh
